UI policy not setting field Read only
ARP3
I have an issue where the UI policy is not making the field Read Only even though the field watcher says, Ready Only set to True.
I don't see Client Scripts or any other BR/ACLs or anything else touching the same field and only able to see UI policy hitting it on reloading form.
Any advice on where else I can check when Field watcher is giving result like this?
ARP3
We ended up using the ACLs for the fields to make it read only. The problem is happening because of the two sections using same variables.
