10-19-2022 02:09 AM
Hi everyone!
I need this requirement where, when I select a value in "Service offering" field, I want to auto populate the "Service" field based the Parent field of the selected "Service offering"
Example below:
If "Service offering" = Offering v1 , then, "Offering" = SAP Enterprise Services
Hope you can help me out 🙂 Thank you in advance everyone!
Incident Management
10-19-2022 02:34 AM
Write a On change client script on service offering table:-
Use the below code:-
var caller = g_form.getReference('service_offering', setLocation);
function setLocation(caller) {
if (caller)
g_form.setValue('business_service', caller.parent);
Please mark my answer as correct based on Impact.
10-19-2022 08:43 PM
hello,
For me it is working perfectly on my PDI.
When you say it is not working what is the behaviour you see?
10-19-2022 08:55 PM
I modified the script and is now working. I removed the "If (caller)" under the function 😀
var serv_offering = g_form.getReference('service_offering', setService);
function setService(serv_offering) {
g_form.setValue('business_service', serv_offering.parent);
10-19-2022 08:57 PM
If my answer helped you can you also mark it as correct.
Thanks.
