Options
03-26-2024 07:43 AM
Within the incident form you can click 'More options' > 'Email' and then the 'Compose Email' form opens for the incident.
Is there a way of adding this to the problem form?
Options
03-26-2024 07:52 AM
Hi @steveturley
- Open a record in the table that you want to enable the email client for.
For example, to enable the email client for the Problem [problem] table, navigate to Problem > Open, and then open any problem record.
- On the form, click the menu icon (
) and then click Configure > Dictionary. - On the Dictionary Entries list, open the first record.
The first record has the record type Collection and does not have any entry for Column name.
- On the form, in the Related Links section, click Advanced view.
- In the Attributes field, enter email_client=true.
If there are other values in the field, separate the attribute with a comma.
- Click Update.
Options
03-26-2024 07:52 AM
Hi @steveturley
- Click Update.
