Diffrence between form design and for builder
SrinivasS218965
Aditya_hublikar
In this video we explain what form views are in ServiceNow, the different methods of creating forms views, a detailed demonstration of form design & form layout. Thanks for watching! If you have any questions please feel free to reach out linkedin.com/in/anna-brundan-86aa891a9 ...
Learn how to navigate and use Form Builder in ServiceNow to create clean, user-friendly forms without writing code. 🎯 What You'll Learn: - What Form Builder is and why it matters - How to access and navigate the Form Builder interface - Adding, removing, and reordering fields - Creating sections...
Hello @SrinivasS218965 ,
I hope you are doing well . Does my response helps you ?
If my response helps you then mark it as helpful and accept as solution.
Aditya
Srikanth_9
Hi @SrinivasS218965,
Form Designer: Traditional drag and drop tool to customize record forms by arranging fields, sections and related lists.
Form Builder: Modern visual tool for creating dynamic and component-based forms with enhanced UI customization.
If the provided solution is useful/working, please Accept as Solution and hit the Helpful.
Thanks & Regards,
Srikanth Akula.
