Error while activating the flow in flow designer
learn nv
I am unable to activate the flow because of below error.
INVALID_CHARACTER_ERR: An invalid or illegal XML character is specified.
I am not sure where is the issue as we don't have any step no. to check which step has the issue. Could you please help.
Harish KM
Hi @learn nv check all the actions or scripts for XML character, that should do
Harish
Harish KM
Harish
Could you please elaborate what do you mean by this? If possible please share a screenshot
There is no XML character in any of the actions for me but still receiving this error.
Greg D
Any luck on this? We are having the same issue. Xanadu patch 7. This is on multiple flows that have not been changed since we upgraded.
There is a Problem record for this but its not published yet so SN knows there is an issue. A work around is to copy the flow which is not ideal. Just from what I gather it is an issue with the v1 to v2 conversion. Hopefully they publish it with a fix soon.
