Flow Designer Error
Kumar54
I am seeing error for flow designer when i changed From one update set to another
Error:  " Your flow cannot be found. Flow sys_id:n"
kaushal_snow
Hi @Kumar54 ,
Error usually means Flow Designer can’t locate the flow snapshot record (often due to missing or corrupt sys_hub_flow_snapshot entries or broken references to subflows or variables)....a practical fix is to copy the flow’s sys_id, go to sys_update_version.list, revert to a previous working version, and verify that all referenced subflows, custom actions, and variables were migrated properly so the snapshot pointers align again....
If you found my response helpful, please mark it as ‘Accept as Solution’ and ‘Helpful’. This helps other community members find the right answer more easily and supports the community.
Thanks and Regards,
Kaushal Kumar Jha - ServiceNow Technical Consultant/Developer
kaushal_snow
Hi @Kumar54 ,
Thanks and Regards,
Ankur Bawiskar
@Kumar54
your question is not clear.
please explain in details.
