Help with a Script please - tell me what I am doing incorrectly
Mark Lanning
We have a Scheduled Job that runs that will look for Incidents that are unassigned and will use the On-Call to assign those, but now we have a Group who does not want that to happen, so I am trying to exclude that group and not having much luck with the script.
assinOnCall() ;
function assinOnCall() {
	var query = 'active=true^assignment_groupISNOTEMPTY^assigned_toISEMPTY^assignment_group!=dcfca1854f88f6c08dab0ad14210c7b6';
	var grInc = new GlideRecord('incident');
	grInc.addEncodedQuery(query);
	grInc.query();
	while (grInc.next()) {
		var group = grInc.assignment_group.sys_id + '';
		var assigned_to = getOnCall(group) + '';
		if(assigned_to != '') {
			grInc.assigned_to = assigned_to;
			grInc.comments = "The assigned to was empty. This Incident was updated using the current on-call resource";
			grInc.update();
			return false;
function getOnCall(groupId) {
	var returnAssignee = '';
	var rota = new OnCallRotation() ;
	var hasRota = rota.who(groupId) + '';
		if(hasRota == 'true^assignment_group!=dcfca1854f88f6c08dab0ad14210c7b6') {
		returnAssignee = rota.getPrimaryUser();
	return returnAssignee;
Thanks for adding me @Voona Rohila  but I am not a developer.
@Sandeep Rajput @AshishKM any help.
Hi @Mark Lanning ,
Can you please confirm about the group which you are trying to exclude.
Function assinOnCall is excluding the below group and all incident assigned to this group should not part of while loop. ( that is expectation )
You can try this filter condition in the List View and check the result data.
If List View is giving same result then check if this group has any parent group configured.
Please test and share the result.
AshishKM,
Yes, there is a Parent Group. I did get the query from the List View.
Should I be doing something different?
This is the Post back in 2018 when I asked help to create this, only difference now, is I have a Group who want to be excluded, where the Assigned to remain empty.
Solved: Update Incidents where the Assigned to is empty du... - ServiceNow Community
Just checking if issue still there.
If the exlucing group has parent group then that also need to exclude, otherwise parent is allowed and all child group record will be visible.
