Incident creation ig group does not have members or owners
Kaustubh k
Hi Team,
We have below requirement,
If any of the group does not have any members or owners or managers then an incident should be created and assigned to a Admins group.
multiple incidents should not be created for same set of groups.
How can we achieve this.
thanks
Hello @Kaustubh k
Sorry for inconvenience caused to you. I have modified script include code and tested this time in my PDI 😉
var CheckEmptyGroups = Class.create();
CheckEmptyGroups.prototype = {
    initialize: function() {},
 checkGroups: function() {
        var gr = new GlideRecord('sys_user_group');
        gr.addActiveQuery();
        var emptyGroups = new Set();
        while (gr.next()) {
            var groupId = gr.sys_id;
            var groupName = gr.name.toString();
            // Check if the group has members
            var memberCount = new GlideAggregate('sys_user_grmember');
            memberCount.addQuery('group', groupId);
            memberCount.addAggregate('COUNT');
            memberCount.query();
            memberCount.next();
            var hasMembers = memberCount.getAggregate('COUNT') > 0;
            // Check if the group has owners or managers
            var hasManager = gr.manager.toString() !== '';
            if (!hasMembers && !hasManager) {
                emptyGroups.add(groupName);
        if (emptyGroups.size > 0) {
            this.createIncident(Array.from(emptyGroups));
    createIncident: function(groupNames) {
        // Check if an incident already exists for these groups
        var existingIncident = new GlideRecord('incident');
        existingIncident.addQuery('short_description', 'Groups with no members & managers');
        existingIncident.query();
        if (existingIncident.next()) {
            return; // Incident already exists
        // Create a new incident
        inc.initialize();
        inc.short_description = 'Groups with no members & managers';
        inc.description = 'The following groups have no members or managers:\n' + groupNames.join('\n');
        inc.assignment_group = 'your_group_sys_id'; // Replace with the sys_id of the Admins group
        inc.insert();
    type: 'CheckEmptyGroups'
Thanks & Regards
Viraj Hudlikar.
11 REPLIES 11
Hello @Kaustubh k
        while (gr.next()) {
            memberCount.next();
        inc.initialize();
        inc.insert();
Thanks & Regards
Viraj Hudlikar.
Thank you so much @Viraj Hudlikar .Its working
