pause the flow in flow designer
Deepika54
Hi team,
In my flow designer, i have 5 catalog tasks and all need to be created at once based on my use case.
I want my flow to be paused until all the catalog tasks are completed. Can anyone tell me how this can be achieved via flow designer
Ankur Bawiskar
@Deepika54
you can create them at once and ensure uncheck Wait checkbox on "Create Catalog Task" flow action
Then you can Lookup and For each to check if all tasks are completed
like this
Flow Designer – Wait for all catalog tasks to complete
vignesh parthib
Hi @Deepika54
Please refer to the following link regarding using Flow Designer in ServiceNow to wait for all tasks to be completed before proceeding:
🔗 Flow: How to properly wait for all SC Task records to be completed
This solution worked well for me in my project.
Vignesh
"If this solution resolves your issue, kindly mark it as correct."
kaushal_snow
@Deepika54 ,
You can utilize a combination of parallel execution and wait conditions. First, group the creation of your catalog tasks within a Do the following in parallel action. For each catalog task, ensure that the Wait checkbox is selected. This setup will initiate all tasks simultaneously and pause the flow until each task reaches a closed state. This approach is effective when the number of tasks is manageable and known in advance. For more complex scenarios, such as dynamically created tasks, consider implementing a subflow that iterates through all related tasks, checking their completion status and pausing the flow until all tasks are closed.....
If you found my response helpful, please mark it as ‘Accept as Solution’ and ‘Helpful’. This helps other community members find the right answer more easily and supports the community.
Thanks and Regards,
Kaushal Kumar Jha - ServiceNow Technical Consultant/Developer
Ankur Bawiskar
@Deepika54
like this
