populate sum of 4 number fiels in other field dynamically
dixitreddy
i have a requirement that in the for there r 4 fields A,B,C,D currency fields or number fiels when i enter this values in the form it should do sum of all these a+b+c+d and populate in other field called E before saving form it self it should calculate and populate
9 REPLIES 9
Hi @dixitreddy ,
You have 4 fields and if you create OnLoad client script it works on only one field. For example you created onLoad client script on Field A and if you didn't change the value of field A the script will not work.
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
Hi @dixitreddy ,
I tried with OnSubmit client script it works for me please check below code
function onSubmit() {
    var fieldA = g_form.getValue('u_a');
    var fieldB = g_form.getValue('u_b');
    var fieldC = g_form.getValue('u_c');
    var fieldD = g_form.getValue('u_d');
	alert('A = ' + fieldA + " B = " + fieldB + " C = " + fieldC + " D "+ fieldD);
    var e = parseInt(fieldA) + parseInt(fieldB) + parseInt(fieldC) + parseInt(fieldD);
	alert("E - " + e);
    g_form.setValue('u_e', e);
Result
Total in E
Thanks and Regards
Sarthak
will it work on onchange? before saving form i need sum of values to populate
Hi @dixitreddy ,
This is will on OnChange client script for example if you apply OnChange Client script on field D, so each and everytime you need to change the value of field D to calculate the sum of all 4 fields
Please mark my answer correct and helpful if this work for you
Thanks and Regards
Sarthak
on change will work only in one field at a time i want to enter 4 values and it should do sum then the on change wont work here
