Problem task is not created for the p1 critical incidents after incident resolve
manikantade
Hello Team,
I have some problem regarding problem task. problem task is not created for the p1 critical incident after closing. could you please help me with this issue.
Thank you.
Dr Atul - LNG
Hi @manikantade
If I'm not mistaken, problem tasks need to be created manually — there isn't a workflow that creates them automatically."
AshishKM
Hi @manikantade ,
Please check and validate the P1 incident and Problem and Problem task relationship logic.
If you found something is not working as expected then share that code.
-Thanks,
AshishKM
AndersBGS
Hi @manikantade ,
 do you have a workflow for this? Problem and problem task are not generated automatically, unless you have a specific workflow for it.
  please check and help me on this
