ServiceNow Tech told me to use side_door.do, not working
11-13-2023 12:26 PM
I was working with SN support with on a SSO issue. We resolved it in my DEV environment but now I cannot login with my admin account. He mentioned to use side_door.do but that isn't working it reroutes me to a page that says session_timeout.do. Are there any other options that I could try to log in via my admin account? I cannot reset the password for my accounts because we have outbound emails disabled. 😞
11-14-2023 04:49 AM
Hi @jaubert
You can try using /login.do to login to your instance even after you enabled SSO. If this didn't worked, I recommend using SSO Recovery account to login using /login.do
Please mark my answer helpful and accept as solution if it helped 👍✔️
11-14-2023 05:19 AM
@jaubert Success of Login using local credentials from /login.do is dependent on Auth Policy Contexts. And from my personal experience side_door.do never worked (at least for me) after Sandiego.
11-14-2023 04:54 AM
I would advise you try via private window by logging via instance/login.do.
otherwise please reach out ServiceNow support .
Luxo
