Setting Capacity for the Advanced Work Assignment Incident Service Channel
Gemma4
Hello everyone,
I need expertise on how to best define capacity for the Advanced Work Assignment (AWA) Service Channel using Incident. Currently, we are using everything out-of-the-box and have created one channel for Incident tickets.
We understand that different queues may have varying volumes of work, so we want to ensure we set a fair and best-practice capacity for the entire channel.
With that said we understand
Capacity = Maximum number of work items a technician can handle at the same time.
AWA uses this to balance workloads and prevent technicians from being overloaded.
Example:
Each work item (incident) = 1 unit
Each technician has a capacity limit (e.g., 3 units)
When a technician accepts work, their available capacity decreases, and AWA routes new incidents only if they have room.
Capacity is defined at the Service Channel level (e.g., Incident) and applies to all queues for Incident teams supporting that channel.
Since multiple teams with different workloads will use the Incident channel, we’re unsure how to set capacity so it works for everyone. Setting a very high capacity could ensure equal ticket distribution, but it may result in some teams receiving more tickets than preferred.
I'm curious how others handle this when workloads vary using out-of-the-box functionality and I want to make sure I understand correctly the channel capacity for the queues setup.
Would it be best to set a high capacity to meet for equal distribution in our first phase of releasing awa out of the box? Is this the right approach to keep things out-of-the-box, fair, and consistent for all teams?
Thank you in advance for any feedback you can provide!
PrajaktaG308421
Mega Guru
Hello @Gemma4 ,
1.Should capacity be high or low initially?
Start high to ensure tickets flow; adjust based on observed workloads.
2.How to handle multiple teams?
OOB doesn’t allow per-team capacity. Use assignment rules, weights, or multiple channels for more control later.
3.How to keep it fair?
Monitor actual workload, not just assigned tickets. Adjust over time.
4.Out-of-the-box focus?
Yes — phase 1 should be simple. Customization comes later.
AWA points to remember:-
Use one channel for Incident tickets.
Set a high channel capacity to allow fair ticket distribution.
Monitor workloads per team and per technician.
Adjust routing with assignment rules, skills, or weights rather than trying to customize capacity immediately.
PrajaktaG308421
Mega Guru
Hello @Gemma4 ,
Laveena-Agarwal
Hi @Gemma4
Assignment behavior in ServiceNow is controlled using the Assign By field in the Assignment Rule, which is part of Assignment Eligibility and configured within Queues.
The Assign By field has two options:
  • Most Capacity:
    Assigns the task to the eligible agent with the highest available capacity.
  • Last Assigned:
    Used for continuity; the system attempts to assign the task to the agent who last handled similar work, provided the agent is still eligible and has available capacity.
I think this video can help you - AWA Assignment and Routing
Additionally, skills can be enforced as mandatory during assignment too. Here is the detailed video - Advanced Work Assignment (AWA) Tutorial: Automatically assign work to agents by skill
Gemma4
Thank you all @Laveena-Agarwal @PrajaktaG308421  for your feedback. It was incredibly helpful and much appreciated
Supriya Mane
Hi total capacity is 5 and daily limit for 2 per day work item how to configure
