‎12-05-2024 07:31 AM
I have a system property and the type is Integer, and the value is 300. After the trigger condition wait 300 seconds of time then execute the remaining flow. But waiting time need to be dependent on the system property value. Can you please help me on this.
If use script action to wait the time please let me know what is the input and output I have to take and what are types needs to take.
‎12-06-2024 05:42 AM
exit the edit mode and then set the value using data pill on that output variable
‎12-06-2024 06:50 AM
@Ankur Bawiskar , I am getting Duration is null after, why this is coming, can you please let me know how to over come this
‎12-06-2024 06:55 AM
Did it work for 2mins as per solution I shared?
‎12-06-2024 07:00 AM - edited ‎12-06-2024 07:02 AM
‎12-06-2024 07:18 AM
It worked for me as per my earlier screenshots where I created timer for 1 min in system property and my flow was waiting for 1 min
Sorry I believe I have already provided a working solution. Now you need to check if you have any errors or you have not configured it as per your requirement.
