08-25-2026 03:12 AM - edited 08-25-2026 03:14 AM
It is 'Additional comments(Customer Visible)' in UI16/Native view but it is just 'Additional comments' in SOW.
We need to have the same field name in SOW view as per U116/Native view
We're not able to find the common dictionary record which contains the same name.
also we're not able to see the dictionary field record (related to UI16 view), that have the name 'Additional comments(Customer Visible)' .
PFB attached screenshots of both view. Please advise.
08-25-2026 04:19 AM
another fix is create your own onload client script on INC which runs on new record and checks if it's SOW
It worked for me on new record in SOW
function onLoad() {
// Check if it's a new record
if (g_form.isNewRecord() && top.location.href.indexOf('/now/sow/record/incident/-1') > -1) {
g_form.setLabelOf('comments', 'Additional comments (Customer visible)');
output
08-25-2026 04:34 AM
@Ankur Bawiskar I need to have that same label when I'm creating a new Incident record in SOW view and also after the Incident record is created in SOW view as well. Please let me know, Thanks!
08-25-2026 05:02 AM
the script I shared worked for new record, there you can enhance so that it shows for new and existing record both
function onLoad() {
if (top.location.href.indexOf('/now/sow/record/incident/') > -1) {
08-25-2026 05:35 AM
@Ankur Bawiskar Thanks, It worked for Me
08-25-2026 05:12 AM
Hi @sharsha,
Check for the UI builder; that is the way you can achieve it.
Let me check this as well!!
If you find my answer useful, please mark it as helpful and correct. 😊
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
