When does it make sense to use a Case instead of going straight to an Incident?
darrelldjoh
Mega Contributor
I’m trying to better understand when an organization would choose the Case route versus going straight to an Incident.
In many DoD/internal support environments I’ve seen, the cleaner and quicker workflow is to open an Incident as soon as a customer calls or reports an issue. That gives the team one record to track the interaction, assignment, troubleshooting, and restoration work. If multiple users are experiencing the same issue, we then open a Problem for RCA and relate the Incidents back to it.
Because of that, I’m trying to understand where Cases really add value in practice.
For organizations using Case management / CSM, when do you decide a Case should be the primary intake record instead of an Incident? What makes that extra step worth it operationally? Is it mainly for customer/account context, entitlements, communication workflows, external customer support, or something else?
I’d be interested in hearing real-world examples of where Case + Incident worked better than just using the Incident-first route.
yashkamde
Tera Sage
Hello @darrelldjoh ,
If talking in short, If you only care about fixing the thing, stick to Incident. If you care about who is broken, what they are owed by contract, and filtering the communication between tech and customer, Case is the way to go.
Real-World Example: The "Systemic Hardware Failure" :
Imagine a scenario where a specific hardware component (an encrypted router) fails at multiple remote sites.
The Incident First Route: You get 50 Incidents. You link them to a Problem. You are now communicating with 50 individual users via Incident comments. It's noisy and disorganized for the account managers.
The Case + Incident Route :
1. Each site opens a Case.
2. The system identifies these sites all belong to "Regional Command X."
3. A single Incident is spun up for the engineering team to fix the firmware.
4. The Value: The engineers work the Incident (Internal). The Customer Service Agents manage the Cases (External). When the Incident is resolved, it can automatically flow up to resolve the Cases, ensuring the communication is tailored to the customer's specific contract or language, while the fix was purely technical.
Thank you — this is a great perspective. I like this approach because it avoids overwhelming the technical team with multiple tickets for the same issue. Instead, a single ticket can be routed to the technical team to address the underlying problem. Once resolved, CSM can coordinate with the service desk to follow up with customers and ensure there are no lingering user issues.
