when sctask work note updated need to create the incident using flow designer
Vinod S Patil
Hello  Everyone
I have requirement when Sc_task's work note updated and if it contains the text ' file creation failed' need to create the incident using flow designer.
I tried it but its not working as expected can you please help me on that and have look at below screen shot.
@Ankur Bawiskar
2 ACCEPTED SOLUTIONS
@Vinod S Patil
do this as alternative and it should work fine for you
1) create flow variable of type True/False
2) then use Set Flow Variables flow logic to set that flow variable based on matching condition
3) then use that Flow variable in your IF logic
@Vinod S Patil
To implement your requirement, here are the detailed steps to create a flow that triggers when a worknote containing "file creation failed" is added to a Catalog Task.
1. Create a Flow with the Following Trigger:
  • Trigger: Updated
  • Table: Journal Entry [sys_journal_field]
  • Condition:
    • Name is sc_task
    • Element is work_notes
    • Value contains file creation failed
This will ensure that the flow triggers whenever someone posts a worknote on a Catalog Task containing the text "file creation failed".
2. Add the Following Steps:
Step 1: Lookup Record Action
  • Add an action to Lookup Record in the Catalog Task Table (sc_task).
  • Set the filter condition:
    • Sys ID = Trigger - Record Updated > Journal Entry Record > Element ID
    • Item = {SELECT YOUR REQUIRED CATALOG ITEM}
  • Set Don't fail on error as checked
This step will fetch the Catalog Task record associated with the worknote, but only if it's for the desired catalog item.
Step 2: Add an IF Flow Logic
  • Add an IF flow logic to check if the record exists.
  • This ensures that an Incident will only be created for the Catalog Task associated with the specified catalog item when the worknote contains "file creation failed"
Step 3: Create Record on Incident Table
  • Under the IF condition, add the action "Create Record" on the Incident table.
  • This action will create a new Incident record based on the conditions you’ve set.
Successful Execution Screenshot
Here’s a screenshot of the flow successful execution:
Positive case:
Negative Case: when the catalog item was not the selected one
If my response helped, please mark it as the accepted solution so others can benefit as well.
Thanks & Regards,
Muhammad Iftikhar
15 REPLIES 15
@Vinod S Patil
then it means IF evaluated as FALSE
Are you using correct TEXT to compare?
@Ankur Bawiskar  yes using correct text,
Any suggestion for this please ?
@Ankur Bawiskar  no its not, its getting false, Please have look at execution flow below.
@Vinod S Patil
did you try adding the Work notes match directly in condition of Flow trigger?
@Vinod S Patil
