Field Message does not display in SOW
Justin Scheich
I have a functional client script that shows the field message in the classic UI for the SOW view. However, it does not show in the workspace. What am I missing here?
function onLoad() {
	//Don't waste an ajax call if the caller is empty
	if (g_form.getDisplayBox('caller_id').value == '')
	//If we're closed, don't query
	if (g_form.getValue('state') == 7)
	var ga = new GlideAjax('LCGIncCheck');
	ga.addParam('sysparm_name', 'getCallerIncidents');
	ga.addParam('sysparm_caller', g_form.getValue('caller_id'));
	ga.addParam('sysparm_num', g_form.getValue('number'));
	jslog("Calling LCGIncCheck for caller...");
	ga.getXML(doAlertCaller);
function doAlertCaller(response) {
	jslog("LCGIncCheck for caller answer is: " + answer);
	if (answer != '' || answer != null) {
		g_form.showFieldMsg('caller_id', answer, 'error',true);
	} else g_form.hideFieldMsg('caller_id', true);
Justin Scheich
I was able to find the solution; The script included does work without a change. It would appear that
is not supported in the workspace and instead needs to be.
if (g_form.getValue('caller_id') == '')
Ramachandran
Hi Justin Scheich
Same requirement i have, but it needs to only work on my SOW workspace , not in Native UI.
What should i do ? Can you please suggest.
If you need a client script to only work in SOW un-check the global check box and update the view to sow.
This will have the client script only run in Service operations workspace.
