Hi All which monitoring tool can be integrated with snow for monitoring server memory, disk space etc...ideally which one is good for snow thank you so much for your continued support
shantilal
Kilo Expert
Shantilal
shantilal
Kilo Expert
Thanks you so much for quick response i really appriciate your help in this regard.
can you please provided the steps to integrate Xymon or Nagios ?
No Problem,
We're all here to help and learn as well.
For Xymon and Nagios, i suggest looking into Event Management. Nagios can be integrated with that I believe.
Here is a link:
Integrating External Events with Event Management - ServiceNow Wiki
bradpsnc
Thanks for the link Vibee! Yep I would recommend using Event Management if you decide to go with either of those monitoring tools.
Brad
mbrike
Kilo Explorer
Shantilal,
your question poses a large list of possible solutions. As some have mentioned above, maybe Nagios is a good bet for you. Anyway, as a software developer who works (A LOT) on a variety of cloud services, I do recommend you checkout a more underground solution in the line of ZenOSS, called Pandora FMS.
This tool is very powerful and offers a fully flexible API for third party integrations. Apart from this, their server monitoring capabilities are some of the best and most reliable you're going to come across.
Personally, I've been using this as an alternative to Nagios, and feel quite satisfied with the performance it's returned, although the choice is always yours. You know what they say, taste is no matter to be judged.
