How many columns does a report can display? Is there any limitation?
qazhu
Dear Sir,
I need help to clarify if there is any limitation on the number of columns can be displayed on a report?  I want to generate a report (list type) with a large number of columns (> 50). I failed. It displayed abnormal. I wonder if there is any limitation somewhere in properties?
Thanks!
qazhu
Dear Saurav
Thanks a lot for your quick response. I will try again.
QA Zhu
If my answer helped you can you also mark it as correct.
Thanks.
Hi @qazhu ,
Go to Reports > Administration > Properties and check there if any property which you can set but as per my knowledge there is no limit that I am aware of, however that doesn't mean one does not exist. 40 columns on a report is a lot. You may want to reconsider your approach. If you feel your requirements validate the need for so many columns, enter a HI / Support ticket and let them know. This could be a bug or it could be a limit that the developers need to consider raising.
Hi @qazhu ,
As i mentioned Please connect with ServiceNow Support , they can actually look into this and help you.
