Active, couldn't classify: No WMI connection, now finished
sukran
We got an error for some windows devices as below in the WMIRunner / WML Classify
<result><error>Failure(s) with available Windows credentials from the instance.</error><error>The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)</error></result>
While did a test in ' test credentials and it has been successfully validated , how to figure out this
9 REPLIES 9
Hi chuckm,
I checked with window server team , they said port 135 has communicate with mid server but ( high port 49152-65535) couldnt
alos they pointed out telling other server which is discovered as expected but this server also same scenario like ( high port 49152-65535 ) in not communicating
how to deal this
sukran,
Are both Windows hosts using the same version of windows? I didn't provide the high ports for older versions of Windows, because most organizations have since upgraded. The high port requirements are different for different versions of windows as follows:
High Ports 1025 - 5000: Windows 2000, Windows XP and Windows Server 2003
High Ports 49152 - 65535: Windows Server 2008 and later versions, and in Windows Vista and later versions
Is it possible to open the high ports temporarily to test Discovery? That way you could eliminate this as the issue and move on to troubleshoot other areas. The key is that for ServiceNow Discovery to discover Windows servers - it uses WMI which uses port 135 for initial communication and the high ports for the remainder of the communication.
monica12
Mega Contributor
Hi , i am facing a similar issue, what did you do to resolve it?
95 % - windows firewall is blocking
5 % - System issue , so you can go to ecc queue-> open shazzam out put -> delete ( processed , created and sequence ) and state change to ready
and insert and say , it will run the job again to update
Mainly its firewall blocking issue
Hi MOnica,
I will always start looking into this issue by going to MID server and following this article:
https://community.servicenow.com/community?id=community_question&sys_id=e99c03e5db9cdbc01dcaf3231f96...
https://community.servicenow.com/community?id=community_question&sys_id=094970fedb07b3c8d82ffb243996...
https://hi.service-now.com/kb_view.do?sysparm_article=KB0549834
Start with looking by running this command from mid server to target machine:
gwmi win32_operatingsystem -computer 192.168.200.14 -credential 'LOCALDOMAIN\mid'
Ashutosh
