Agent Client Collector ACC-V - How to Launch Powershell Script on Agent through Check Definition
01-28-2022 08:38 AM
Has anyone successfully managed to get a Check Definition to run a Powershell script on an Agent?
Our business requirement is to get a Virtual Agent Topic to use the ACC Spoke to invoke the Flow Action 'Run Agent Client Collector Check Definition'.
The challenge is how to configure the ACC Check Definition as I can see no examples that run Powershell scripts on the agents only osquery as they supplied Ruby Scripts are provided OOTB. We can get the VA Topic to call the 'Run Agent Client Collector Definition', but I'm having issues understanding the correct syntax in the Check Definition to launch a Powershell script on the agent.
09-03-2024 08:59 AM
Please can you share link to the article for your findings.
