Configuring Instance Connection for vRealize Operations with this error: Connection test failed: vRealizeJSv1 Connector Test Connection response code: 401
07-12-2020 10:07 PM
Operational Intelligence
10-27-2020 10:59 AM
Hi Rahul,
Yes, from MID server we are able to access vROps console.
Have you successfully implemented ServiceNow vROPS integration using OOB connector?
What is the version of vROps? we are trying to integrate with vROps 8.1.
RRR
10-28-2020 12:31 AM
Do you have the correct credentials to execute the REST message test defined?
RP
01-05-2021 03:51 PM
Hi Rahul,
Yes, I do have correct credentials.
Rewanth
12-17-2020 12:02 PM
I am having the same issue. I can log into the vRealize Operations Manager with the credentials, but cannot get the connector to connect. Has anyone gotten it working? Also on 8.1
01-05-2021 09:59 PM
I am not using this forum anymore, is useless. A lot of people that do not know about the Tool keep posting trash here, to make you waste your time for nothing. You can see in this thread a lot of examples of what I am saying here. The issue is about basic authentication, you need to configure vRops to accept that.
https://kb.vmware.com/s/article/77271
It will fix the problem and no, you don't need mark as resolved because I am here to help and I hope the others too. I am sorry to say that, but really, I am really upset about waste of time here, people are here begging to mark theirs answers as resolved ...
