Discovery is not able to pull the serial number for zebra model printers and from some firewalls
Hello Experts,
Discovery is not able to pull the serial number for Zebra model printers and some other model firewalls. Is there any reason why there is no serial number being returned for only these specific models? Other than serial number, discovery is able to fetch all other details.
Is there any specific reason for this? Is there something i need to do to get the serial number?
Please help me.
Thanks in advance.
24 REPLIES 24
HI,
You can ask your printer team for the proper MIB files and also check with them if you have some re usable MIB in this instance.
Ashutosh
Hi Uday,
We have similar issues with Zebra printer, may I know how you resolved this issue please?
Thank you and looking forward to your response.
Selva
GB14
We have the same issue with Zebra printers discovery. Our SN # field is coming back blank.
We had the same issue, I had logged a case with ServiceNow and worked with them,we had customized the classifier which eventually fixed the issue. I will share the fix in community.
If you believe the solution provided has adequately addressed your query, could you please **mark it as 'Helpful'** and **'Accept it as a Solution'**? This will help other community members who might have the same question find the answer more easily.
Thank you for your consideration.
Selva
Thanks @Selva Arun for your response.
The article and update sets include the workaround to fix the missing IPAddress issue but we are missing the SN # for only the zebra printers.
