Discovery is not able to pull the serial number for zebra model printers and from some firewalls
Hello Experts,
Discovery is not able to pull the serial number for Zebra model printers and some other model firewalls. Is there any reason why there is no serial number being returned for only these specific models? Other than serial number, discovery is able to fetch all other details.
Is there any specific reason for this? Is there something i need to do to get the serial number?
Please help me.
Thanks in advance.
24 REPLIES 24
Please find the below article for your reference:
How to Successfully Set Up SNMP Discovery for Zebr... - ServiceNow Community
If you believe the solution provided has adequately addressed your query, could you please **mark it as 'Helpful'** and **'Accept it as a Solution'**? This will help other community members who might have the same question find the answer more easily.
Thank you for your consideration.
May i know if the case you opened fixed the issue for NonLinkOs Zebra printers ?
In our case the serial number is left empty. So hopefully the case you mentioned is resolving the issue ?
thanks in advance for the reply
John
Hello @brukasmj
Zebra printers discovery is not supported OOB. You will have to create a custom sensor and probe. The above link was a good startup point for me and we were able to get device SN. You need a correct/latest MIB file, OID etc to start, and the Zebra website is the right place to download it from.
G
To address the issue you're facing with the serial number being left empty for Zebra printers, the case I opened includes a proposed solution. However, the solution provided by @Selva Arun is more detailed. You can find the steps and further details for resolution in the following link:
https://www.servicenow.com/community/itom-articles/how-to-successfully-set-up-snmp-discovery-for-zeb...
Hope this helps!
Thank you so much for mentioning my article.!
