Discovery issue with NetApp Storage Cluster-Mode Pattern
SunilKumar_P
Hi Experts,
I am trying to discover a storage device and I do see the classification is working as it is getting OID data. However, the device is not being created in the cmdb table.
Error:
Identification Engine: Discovery status is FAILURE, CI Type cmdb_ci_storage_server cannot be created since there are no attributes defined. Debug pattern to understand why no attributes have been assigned.
Has anyone experienced this error? If yes, what was the fix?
Hi @AJ_TechTrek & @Pratiksha  - I have tried to debug the pattern NetApp Storage Cluster-Mode on cmdb_ci_storage_server and here is my observations:
Step - get full intrface -> getting all the devices like clusters, svms and nodes
Ex:
vserverip_addresshome_portcomment
clusterx.x.x.10e3a
clusterx.x.x.11e3b
clusterx.x.x.12e3a
cluster1x.x.x.13e0m
cluster1x.x.x.14e0mThis is actual server
cluster1x.x.x.15e0m
Step - remove duplicate ports from ips_info -> considering only one record each unique port and here the svm (server) record is being ignored and only the cluster record is condidered due to which the server record is not being inserted .
clusterx.x.x.10e3a
clusterx.x.x.11e3b
cluster1x.x.x.13e0m
Hi @SunilKumar_P ,
I am not getting this, can you please help to elaborate more on this.
Please appreciate the efforts of community contributors by marking appropriate response as Mark my Answer Helpful or Accept Solution this may help other community users to follow correct solution in future.
Thank You
AJ - TechTrek with AJ - ITOM Trainer
LinkedIn:- https://www.linkedin.com/in/ajay-kumar-66a91385/
YouTube:- https://www.youtube.com/@learnitomwithaj
Topmate:- https://topmate.io/aj_techtrekwithaj (Connect for 1-1 Session)
ServiceNow Community MVP 2025
