01-30-2024 01:48 AM
As reopen count of incidents are increasing again and again and i need to create a problem ticket for every 30 reopen incident, that is the reopen count reaches 30 it create one problem ticket. When the same event comes again then the new event create and the reopen count in that incident reaches 30 new problem ticket create and the same is going on , please suggest any flow or something which helps to resolve the issue.
Event Management
01-30-2024 03:39 AM - edited 01-30-2024 03:59 AM
Hello @mirza_saquib -
You can write after update Business rule ,
// Check if the incident has been reopened
if (current.state == 2 && previous.state == 7) {
// Increment the reopen count
var reopenCount = current.reopen_count ;
// Check if the reopen count is a multiple of 30
if (reopenCount % 30 === 0) {
// Create a new problem ticket
var problemGr = new GlideRecord('problem');
problemGr.short_description = 'Auto-generated problem ticket for multiple incident reopens';
// Add any additional fields as needed
var problemSysId = problemGr.insert();
gs.info('Created a new problem ticket with Sys ID: ' + problemSysId);
})(current, previous);
Please Mark ✅Correct if this solves your query and also mark 👍Helpful if you find my response worthy based on the impact.
Pratiksha
Pratiksha
01-30-2024 11:15 PM
Hi @Pratiksha2 ,
After this BR after 30 reopen incident problem ticket will create, If the problem get resolved this BR close the incident?
and if the same event trigger it will create new incident it repeats the above process?
Thanks & Regards
Mirza Saquib Beg
01-30-2024 11:29 PM - edited 01-30-2024 11:29 PM
Hello @mirza_saquib ,
The provided Business Rule (BR) script is designed to create a new problem ticket in the ServiceNow platform when an incident is reopened and the reopen count reaches a multiple of 30. However, the script does not contain logic to automatically close the associated incident or create a new incident.
Pratiksha
02-08-2024 02:55 AM
Hi @Pratiksha2
I need to customize the event property like currently the property is reopen alert will reopen the incident, So every time the alert reopen it will reopen the incident but I need to create the new incident every time when the reopen count of incident reaches 30 or in other word the overall event count in alert field reaches to 31, then every time it will create the new incident . So is there any way to achieve this?
