help with Reporting on Discovery Results
sgrant
I have been struggling with this for a few days, and would love any help I could get. I've looked everywhere, I can't find anything that I've been able to work with.
I am trying to build a report that shows a listing of the devices on the network that are NOT permitting Discovery to run on them. I need to be able to provide this list to the Server Admin team, so they can correct the deficiencies.
I believe I have done the first part, the 2nd, and most challenging, is to restrict the displayed devices to a single instance of each device. 😐 😐 At the moment, I have to export the report to excel and munge it there, to get what I need. If I could do this with a script in the report itself, it would save me much time and effort.
I have attached a screenshot of what I have so far
thanks for your time!
Sandy
Can you schedule reports from this?
Hi Wade,
Definitely. You can navigate to File > Schedule to send it out on a regular basis: Screenshot 2015-02-03 10.38.23.png
Also, if you set up the data source directly against ServiceNow (rather than exporting and importing a spreadsheet) then when you select Publish, you can publish directly to ServiceNow dashboards, and the users will be able to drill through to the ServiceNow data.
If you want to try integrating with ServiceNow directly, it's under Data > Add a New Data Source, and there will be instructions on how to add a ServiceNow data source.
