How to exclude Virtual Machine from Intune integration?
AnciaM
I am looking for a way to exclude any virtual machine from the Intune integration.Is there a way to achieve in ETL Transform Map.
18 REPLIES 18
As per your earlier comment, it was changed to beta/deviceManagement/managedDevices?$filter=model ne 'Virtual Machine'
@AnciaM Have you checked the step logs ?
This is the error it is throwing in the flow designer executions
@AnciaM Clear the api version value. It should be either beta or V1.0.
I'm assuming that you are using both.
V1.0 in the api_version and beta in the nextLink URI
Kieran Anson
Rather than customising the OOTB data resource, the clients azure administrator can create a role definition that provides only the necessary access. The ServiceNow documentation states to provide the 'reader' role which is a built-in role in Azure.
The azure administrator can specify a new role definition and add the following restriction, which would limit access to compute resources
"NotActions": [
    "Microsoft.Compute/*"
