How to get stack group connected IP Switches using discovery?
Madhav9
Hi All
As an OOB feature discovery is not bringing stack mode of a switch as well as stack switch members. While i'm looking through the probes, in "Network Switch" probe I have found a library which is called "Stached Switches". But it is empty and nothing configured.
Could anyone help me regarding this how to get stack details of a switch and able to build relationship between stacked master switch and member switches?
doug_schulze
If you expanded the library in that pattern it should show the steps.  If there are none there, then you may have had a troubled upgrade and should call support.  Also be sure you are using Horizontal Patterns in your switch classifier for it to be used.
Michael, so our discovery of Cisco Stacked switches is working correctly most of the time.
Serial Numbers are being picked up for the main and secondary switches - obviously, there needs to be an SNMPv3 credential on each on.
Here's a screen shot of one, we are on Vancouver.
Thanks mate. Yeah our is working for Cisco switches but not Aruba switches. I believe it's a difference in the formatting of the SNMP response. We may need to look at a custom pattern.
