Issue with Credential Validation in Discovery Fundamentals On Demand (Module 4)
昭彦古
I am currently taking the Discovery Fundamentals On Demand course.
In Module 4: Credentials and Probes, Task: Create Credentials, I am experiencing issues when testing the provided credentials.
Steps I followed:
  1. Created Windows Credentials with the following values:
    • Type: Windows Credentials
    • Name: Windows Servers
    • User name: workgroup\administrator
    • Password: 1G00dDemo
    • Test target: 198.51.12.119
    → Result: “Authentication failed”
  2. Created Linux Credentials with the following values:
    • Type: SSH Credential
    • Name: Linux Servers
    • User name: disco
    • Password: Rdisco01
    • Test target: 198.51.188.74
    → Result: “Could not connect to specified port”
Troubleshooting I have already tried:
  • Re-entered credentials manually (checked case sensitivity and backslash format).
  • Retried on both personal and corporate PCs, also in private/incognito browser mode.
  • Restarted and relaunched the lab environment.
However, the issue persists and I cannot proceed to the next tasks.
Could you please confirm if there is an issue with the lab environment for Module 4, or advise how I should continue?
Vijaya_Mnpram
@昭彦古  They are working fine for my lab instance, but the credentials mentioned are very different from you (this might depend on region).
All I can suggest is to try changing the user name to 'administrator' instead of 'workgroup\administrator'.  Else, submit a Case on the Servicenow University, stating the problem.
My lab creds are:
Windows Credential:
User name: itomadmin
Password: Disco2learn4fun@1!
Save and then Test the credential against: 192.168.16.11
SSH Credential:
Password: LinuxDisco4Fun@1!
Save and then Test the credential against: 192.168.16.12
I tried with the information you provided, but it didn’t work. I’m planning to submit a case.
Harish Bainsla
Hi @昭彦古 I think you just copy paste the credentials instead of it write password manual then it will work .
if my answer helps you mark helpful and accept solution
昭彦古
In the end, I submitted a case to ServiceNow University and had them set the task result to successful.
@昭彦古 Glad to hear you this. Hope you complete the rest of the course successfully.
