Lab Task(Create itunes Discovery Pattern (Part2)) is not performing normally
KyungYun
Please give me your advice.
As I perform quick discovery for lab's verification, discovery log shows the following error message and is not performing normally
Error Message : "Discovery status is FAILURE, Discovery using patterns failed due to lack of existence of the main CI type in the results. Check the discovery logs for more details"
so, When i check the application(iTunes@ip-198-51-12-119),
Only Name Field is populatedVersion, Description is not populated
I captured pattern designer setting
AJ_TechTrek
Hi @KyungYun ,
Refer the below KB articles, which may help you.
https://www.servicenow.com/community/itom-forum/classify-and-discover-itunes-running-on-a-window-ser...
https://www.quicknexus.com/blog/discovery-fundamentals-training-lab-faqs
Please appreciate the efforts of community contributors by marking appropriate response as Mark my Answer Helpful or Accept Solution this may help other community users to follow correct solution in future.
AJ
Linkedin Profile:- https://www.linkedin.com/in/ajay-kumar-66a91385/
ServiceNow Community Rising Star 2024
12 REPLIES 12
AlexUGA
Version should be $cmdb_ci_appl[].version
Sara Saravanan
These screen shots must be helping you. Please update the value and name accordingly . Please mark it as helpful incase if this is useful
Wenhui
For the versions step, setting both value and name as $cmdb_ci_appl[1].version did not work for me for some reason, but I tried hard code the value to the value in the payload, ("12.7.0.166" in my case) and it worked. Not sure why tho.
