Missing pattern-based outgoing connections from load balancer. Please check the correctness of the incoming connection
pavanyuvi
We are getting the below issue
"Missing pattern-based outgoing connections from load balancer. Please check the correctness of the incoming connection"
only loadbalancer information is populating,please find the attached image.
In discovery log it is showing it is taking as "citrix netscaler pattern",Identification is running fine but in connections
Executing SSH command: show vserver | grep ciname
2018-09-24 11:48:29: Executing SSH command: command -v sudo
2018-09-24 11:48:42: Command result: ERROR: No such command
2018-09-24 11:48:46: Command result: Warning: Feature(s) not enabled [GSLB]
2018-09-24 11:48:46: Execution time: 16956 ms
get policies rules and actions relations
2018-09-24 11:48:46: Step condition is false. step not executed.
2018-09-24 11:48:46: Execution time: 0 ms
get our vip policies
keep all relevant rules
keep policies matching our port or not matching on port
get all actions
merge actions and actions name
extract vservers from actions
get vserver info
extract members and ports
 Create connection
verify no connections
filter out all connections with non operational status and without ip address
keep all connections with port 0 empty * or null on seperate table
remove all connections with port 0 empty * or null on seperate table
replace empty ports with real ports
union both tables
2018-09-24 11:48:46: setAttribute(connections,[])
Create connection
Pavan
angel_jimenez
Mega Expert
Hi @pavanyuvi!
Did you get to solve this issue? I'm facing same error and don't know how to continue here... 😞
Thanks in advance!
Hi, did you find out the solution to this please?
UPDATING, I have found the solution!
That happened when you have F5 loader balancer. when the load balancer has no IRule, the pool wont forward the connection further, the Pattern will pick FQDN instead of the IP, so what you need to do:
  • Go your F5 in your CMDB -> load balancer pool
  • Locate you application service and open it
  • Go down to load balancer pool members
  • Under the name you find the ip addresss
  • Under the IP address you might find a fake FQDN instead of the ip ( here is the problem)  because under the ip address should be an ip matching the one under the name
you can fix this manually, but whenever you run discovery, it will come up again as fqdn. to fix this problem permanently:
  • Go to Discovery Pattern -> search for  F5REST
  • F5 LB REST identification
  • Search for fqdn step
change the fqdn attribute to ip
  • Save -> push
  • Sync the pattern to the mid server -> run discovery again
Please mark it green answer so everyone gets the solution 🙂
Hi @HamzehAlsheikh , I am facing same issue and I tried your solution. However it is not helping. Please suggest. Thanks
HamzehAlsheikh
  • Save -> push
Please mark it green answer so everyone gets the solution ðŸ™‚
