Need Help with SNMP OID
Mike_R
I'm having issues with Discovery on Wyse Terminals (Teradici 7030). I can't populate the serial number.I believe the problem is with the OID. Does anyone know how to get the correct OID to pull serials numbers through snmp for this model?
Mike
So as I said above, you will need to find out the new OID by performing an SNMP walk to the device, I described the process above.
Doing the SNMP walk will print all the OIDs, then you get the new one for the seriel number.
Mark
@tompowe  Hi Tom. I have the same question. I hope you have found the solution. If so can you share the details please.
Hi @Mark Skinner  , could you please answer this.
