Network devices discovery issue
I am having the device for which single IP is cofigured against two different hostnames with different serial numbers.
Means it is a cluster type.
but we are able to discover single device instead of two devices in servicenow.
Please guide me.
Thanks & Regards,
Pritesh
SiD2
Hi @Community Alums
I meant to check the discovery logs not to validate that pattern name or content. Please check and you can debug pattern too.
If you are unaware of this stuff, I would strongly recommend to create a support case with us and someone will assist.
13 REPLIES 13
SiD2
Hi @Community Alums
Yes, ideally it should. We have a stacked switches library in the network switch pattern that discovers both master and slaves and creates relationships b/w them too.
If you don't observe that happening, check the discovery pattern logs and let us know here.
Below is the pattern available here in my env.
step {
name = "Stacked Switches"
comment = "Shared library has been disabled for unsupported Cisco Nexus switches to avoid creating secondary switch CIs for Nexus FEX. CIsco Nexus don't support switch stacking."
if {
condition = eq {
get_attr {"isNexus"}
"false"
on_true = ref {refid = "3cc3da63db71d3406ec43220ad96197a"}
on_false = nop {}
please gudie me.
try this way
yes
refer below image
Please click on "help full" it resolves your issue.
HI @SiD2 & @konijetisumanth,
I got the master-slave point and our customer have done with it.
customer have configured the one as master and one as slave.
but still we are unable to discover the devices.
i have shared you the pattern which is used in discovery.
