Newly added fields are not showing in operating system drop down.
‎08-14-2023 01:54 AM - edited ‎08-14-2023 02:26 AM
Newly added fields are not showing in operating system drop down even after fields are added successfully and active.
New fields are added in computer table.
‎08-17-2023 03:48 AM
Well, it seems your choice is not created correctly.
Compare to how it looks when I created a choice.
Steps I took to create my choice:
1. Open a record in the cmdb_ci_computer table
2. Rightclick on the Operating system field
3. Select Configure dictionary
4. Click on the Choices related list
4. Click New
5. Fill in the Label and the Value
6. Submit
‎08-14-2023 02:17 AM
‎08-14-2023 02:27 AM
Check this active/inactive status, but did not worked.
‎08-14-2023 02:34 AM
Please check once on dictionary
system defination=> dictionary=> table_name = "computer"
‎08-16-2023 02:11 AM
checked this one.
Created new choices for the same "system defination=> dictionary=> table_name = "computer"".
