Newly added fields are not showing in operating system drop down.
Ajinkya Kove1
Newly added fields are not showing in operating system drop down even after fields are added successfully and active.
New fields are added in computer table.
11 REPLIES 11
Sruthi17
So, when you say newly added fields I assume new fields are created. So, to make them available in the form you may need to add the newly created fields by "Configure form layout".
If the above solution is not appropriate kindly share more details about your issue.
Please mark my reply as Helpful and/or Accept Solution, if applicable. Thanks!
Newly created fields I mean new choices I have created which should be shown in the Operating system drop down.
As per current status the choices are created successfully but not showing in the drop down.
