‎04-30-2018 11:16 PM
When I tried to discover printers,not all information of printers being populated in table.For almost 80% printers Manfacture id and model id has not been discovered.
We tried attaching MIB files of respective manfacturers and run the discovery but still the information has not been discovered.
Is there any other way to discover that information?If so mention the process.
Thanks in advance,
Ankitha.
Discovery
‎05-25-2018 01:05 PM
you'll see this when you do not have a SNMP SysOID for that printer model/mfg.. Just add to this list.. (you'll find the number in the system section of the SNMP classify probe..
I also did this part in this youtube video... Remember you dont have to do the whole process Im outlining , just adding the snmp system oID
https://www.youtube.com/watch?v=6ULRbpGOSB4
‎09-04-2019 08:44 AM
Doug,
I know this is an old thread. But what if I'm trying to populate model ID information straight from the pattern? It doesn't seem to want to populate the model id and manufacturer reference fields.
I have a pattern discovering HP Blade Systems, it identifies on the Onboard Administrator, but then from this I can do an HTTP get call to capture the blade chassis and blade server information, so the plan is to build the CI's from that http get call. So far I have it populating the name of the chassis, the serial, the ip address but not model or manufacturer.
Any thoughts?
‎09-04-2019 08:50 AM
3 weeks ago - last edited 3 weeks ago
@doug_schulze I have a follow-up question.
I am running discovery and collecting information about printers. The CIs were created, but the Model ID is Unknown because there is no matching record in SNMP OID Classifications. I want to add record in this table to match OID with model but wandering about one thing. The Model (model) field on the discovery_snmp_oid table is a String type, but the Model ID (model_id) on CI is a reference field to (for printers) Hardware Models (cmdb_hardware_product_model) table. I can see that Name (name) field in the Hardware Models (cmdb_hardware_product_model) table is matching with Model (model) field value in the SNMP OID Classifications table. And now the question: do I need to create records in the Hardware Models (cmdb_hardware_product_model) table or they will be created automatically?
