Reference field to show inactive users for catalog item and assoc. tasks
Blair5
I found a discussion regarding inactive users being shown on a catalog item. --> Reference field not showing inactive users for our asset team
I'd like to show the inactive users on the catalog item (Offboard a user) and all subsequent tasks. The discussion I found addresses catalog item part, but not the TASK part. Does anyone have any ideas?
on the existing br you only need to modify ONE line.. find the if line that kicks it off and change it to
if (!gs.hasRole('user_admin') && !gs.hasRole('view_inactive_user') && (current.getEncodedQuery().indexOf('sys_id>')== -1))
<this adds the encoded query requirement to it>
then just add the ref qualifier to ANY reference field you want to show disabled users of   sys_id>''
26 REPLIES 26
Any users can use it.
Hi Blair,
I think it will be tough to achieve by altering anything in the query business rule, because system will never know in the query business rule where this is calling from any specific table or any specific catalog item.
I think you will need to disable the business rule and achieve this using read ACLs on user table. But using ACLs one drawback is other than admin user, users will see a security constraints message always.
Best way to achieve such type of requirement is to have one more text variable under catalog item variable, where user can enter text / name of the user.
Please mark answer as Helpful/Correct, if it was really helpful
Solutioner
Enhance Knowledge NOW@ www.solutioningnow.com
http://www.solutioningnow.com/
Small change in my query.
Instead of >=0 in condition...do ==-1.
Still no luck
I have this working on two different catalog items in our instance... on the item make it a reference field to sys users...
add this as a reference qualifer... sys_id>''
now go find the BR for "user query that runs on sys_user table... and on the if statement make it read...
from there it should simply work..if this resolves your issue please mark this as answered.
