Storage Discovery 3PAR 8440
abusch
Giga Contributor
Has anybody discovered a 3PAR 8440, OS version 3.2.2 ?
We are new to storage discovery.   I've created the CIM credential in ServiceNow and granted it admin privileges on a sub-prod device.   Are we doing something fundamentally wrong?   Or do we need to do some extra work to support this device? The CIM probe is returning:
<results error="CIM_RegisteredProfile{{RegisteredName='Array'}}.CIM_ElementConformsToProfile{{ResultClass:'CIM_ComputerSystem'}}.ElementName - CIM_RegisteredProfile - CIM_ERR_INVALID_NAMESPACE: interop" probe_time="117"><result/>
Tony
16 REPLIES 16
Hi Bradley, i've got the same issue - did you get anywhere with this?
Steve
Lucky11
I'm trying to build CMDB for HP3par, however, I'm not using discovery modules. I will add the HP3 Par device manually. Can someone share, in which out of box table this is being discovered?
Under storage menu(see below image), I could see Servers/controllers etc., Not sure where to add 3 Par device. If someone could share the hierarchy, that would be helpful.
