Access control help
I've created a "READ" access control which has worked...ish. For some reason its now showing a blank placeholder where the record should be, any ideas how I can just remove this completely?
I did try and configure it instead however the dynamic "is one of my groups" didnt seem to work so had to go down the scripting route.
Script condition
answer = true;
if (current.u_nda) {
	var group = current.u_authorized_group;
	if (!gs.getUser().isMemberOf(group)) {
		answer = false;
Hey all, I managed to get it working using "addEncodedQuery()" which is actually really simple.
//When to run: Before
//Order: 1000
// Query: True
(function executeRule(current, previous) {
    var query = '';
    query = "u_authorized_groupDYNAMICd6435e965f510100a9ad2572f2b47744^ORu_authorized_groupISEMPTY";
    current.addEncodedQuery(query);
})(current, previous);
Thank you everyone for your help!
14 REPLIES 14
@Community Alums
got it
That's how ACLs work.
If table has 100 records and only 10 satisfy then those 10 records are scattered and user has to scroll to the next page
To overcome this you can use query BR on that table and have similar query
BR Condition: gs.getSession().isInteractive()
Script:
    // Add your code here
    var groups = new global.ArrayUtil().convertArray(gs.getUser().getMyGroups());
    current.addQuery('u_authorized_group', 'IN', groups);
    current.addQuery('u_nda', true);
Hi Ankur, thanks for coming back to me. Unfortunately neither have worked, I'm going to give another crack at it however if you come up with any other ideas in the meantime I'm all ears! 😁
@Community Alums
did you try the below script?
Also are you sure you have table.None READ ACL on your table?
Are you having the same issue which I mentioned above i.e. records are scattered on next pages and user has to scroll?
Currently its * I did try "None" however it stops working when I do.
@Community Alums
you should have table.None READ ACL with same advanced script
table.* READ is not required.
Did you create query BR and verify it? did you try the updated query BR?
    current.addEncodedQuery('u_nda=true^u_authorized_groupNOT IN' + groups).addOrCondition('u_nda', false);
