Activate SDLC Plugin
vikas22
How to activate SDLC plugin?
we have a requirement to use waterfall model with release management.
If the SDLC plugin is activated, both the SDLC and Release Management v2 applications are available.
But I'm unable to activate SDLC plugin.
Hi Vikas ,
Here I found something which might help you :
The ServiceNow Agile Development 1.0 application helps you manage and track software development life-cycles through an iterative, incremental, and flexible approach.
Note: Starting with this release, Agile Development 1.0 plugin (com.snc.sdlc.scrum.pp) is no longer visible or available for you to activate. Activate the Agile Development 2.0 plugin (com.snc.sdlc.agile.2.0).
so you try and activate this plugin and see if it helps otherwise request for your plugin as shown in the snap:
Apeksha
Indrajit
Mega Guru
Hey Vikas,
Refer below similar thread might help you out.
https://community.servicenow.com/community?id=community_question&sys_id=bd1ffa29db58dbc01dcaf3231f96...
Mark Correct and Helpful if it work.
Indrajit
vikas22
It was showing in Geneva version but not in Newyork
