Add groups to variable field through automation.
07-09-2025 03:44 AM
Hi Everyone.
I have a requirement where i need to add groups of one variable to other variable in a catalog item.
We have one variable called AD group, and other variable Company groups. This company groups is a list collector variable it has reference to a company group table. In every record company group table there is one variable called Org groups. When we select any company group record , the data in that org groups field of that particular company group should be appended to AD group variable. How can i achieve this?
Thank you in advance.
07-10-2025 04:44 AM
Hi
Function name has to be what you provide in sysparm_name, in your case function name is different in script include GetAADValues.
Also try to add logs to check where your code is creating issues
Thanks!
07-10-2025 03:01 AM
try this
var GetOrgValues = Class.create();
GetOrgValues.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getOrgValues: function() {
var ids = this.getParameter('sysparm_ids');
if (!ids) return '[]';
var idArray = ids.split(',');
var result = [];
var gr = new GlideRecord('u_company_group');
gr.addQuery('sys_id', 'IN', idArray);
while (gr.next()) {
var aad = gr.getValue('u_org_group');
if (aad) {
result.push(aad);
return JSON.stringify(result);
Client script:
var selectedIDs = g_form.getValue('u_company_groups');
if (!selectedIDs) return;
var currentADGroup = g_form.getValue('vo_ad_groups');
var ga = new GlideAjax('GetOrgValues');
ga.addParam('sysparm_name', 'getOrgValues');
ga.addParam('sysparm_ids', selectedIDs);
ga.getXMLAnswer(function(response) {
if (!response) return;
var aadvalues = JSON.parse(response);
var newADGroupValue = currentADGroup;
if (aadvalues.length > 0) {
// Remove duplicates if needed
var existing = currentADGroup ? currentADGroup.split(',') : [];
var combined = existing.concat(aadvalues);
// Remove empty strings and duplicates
var unique = Array.from(new Set(combined.filter(Boolean)));
newADGroupValue = unique.join(',');
g_form.setValue('vo_ad_groups', newADGroupValue);
07-10-2025 03:41 AM
Hi @Ankur Bawiskar , i have tried this and i am getting error like "there is java script error in your browser".
I am getting an error when i try to fill company group variable.
BR
07-10-2025 03:58 AM
sorry but you didn't share what debugging did you perform?
share screenshots of your form, variable configuration etc
