‎04-16-2018 09:16 AM
Good morning,
I have been tasked with putting the incident comments and work notes onto the incident task notification email. I found a script that I believe can be modified for the task, but I thought I'd see if there was a better solution out there in the community before I committed to this path.
Thank you in advance!
Tyler
‎04-16-2018 09:28 AM
I would just reference via the available variables in the notification set up on the What it will contain tab - open variables, hit the + next to incident, then select Comments and work notes - this will automatically put it into the notification.
‎10-15-2018 03:56 AM
Hi Timmo, would this be the mail script?
‎10-15-2018 01:34 PM
Yes, you can put it in there. Alternately, you can do what is suggested in the accepted answer, as that effectively does the same thing.
Tim
‎04-16-2018 09:47 AM
I never actually considered that. Thank you!
‎04-16-2018 09:53 AM
You're welcome!
