addDays function not working correctly
sndev1099
Giga Expert
I have created an after business rule on the issue table with the following conditions:
Materiality rating (on associated control) = high
Status (on associated control) = non compliant
My code:
var date = new GlideDateTime();
date = current.start_date;
date.addDays(25);
current.end_date=date;
)(current, previous);
All I'm wanting to do is add 25 days to the planned end date field on the issue. Can anybody point out what I'm doing wrong?
Ahhh Scoped app of course, addDays will not work on that.
Kind regards,
Mark
LinkedIn
Allen Andreas
If you're unsure what you're getting or if this script is even working...you really need to use log statements, etc. to troubleshoot. Since now you're wondering if your conditions are the issue. Please remove conditions and test without and add log statements to see how things are going.
If the start_date and end_date fields are Date only fields...not DateTime...you're going to run in to possible problems.
You can try:
date.setValue(current.start_date);
date.addDays(25);
otherwise if it's Date only:
var date = new GlideDate();
date.addDays(25);
sndev1099
Giga Expert
Thank you all. Turns out addDays was the issue and I had to use addDaysUTC for sn_compliance_control.
Kind regards,
Mark
LinkedIn
Glad you got it resolved. Technically, you answered your own question, which should be marked as Correct so that people don't see a different reply marked as Correct thinking that's what resolved it, but since you didn't state that it was a scoped app in your original post, perhaps they won't be confused... Just throwing that out there.
