Advance Reference Qualifier depending on other field
Gaurav Rotke1
On the form there are two fields
one is parent field and one is type field. As type changes to 1 I want parent filed should only show the record with which are type 1 and when type 2 is selected, the parent filed should show type 1 and type 2 record.
I tried coding few times but its only showing either type 1 records for all the type or its showing type 1 and 2 records for all the types, its not changing as we change the type filed.
I am using advance reference qualifier with script include. Any suggestion or improvised code would be helpful.
Thank you in Advance
Please refer the image for code
Hi Sagar,
Its only working as a simple reference qualifier and only satiesfying one condition, as its doing for my code.
In what case is it working/not working?  Have you checked the "Value"s of your Choice List items for "Type" (I'm assuming a Choice list).
