10-31-2019 09:42 AM
My first post! I'm working on a Advanced reference qualifier that calls a script include based on a custom field on our incident form called u_restricted. The goal is if that is flagged true on the ticket then the reference qualifier that calls the script include will query a list of assignment groups that are for restricted tickets they also have the u_restricted field. Below is the code I have thus far and its failing dismally hoping some of your more well versed admins can lend me a hand. I'm about a year into my ServiceNow adventure so still learning the ropes. Appreciate any help!
Here is my dictionary override with the reference qualifier segment.
Here is the Script Include code:
function CNDTCheckRestrictedStatus()
var assignment=[];
var restricted = current.u_restricted;
//return if the current restriction status
if(restricted == false)
var groups = new GlideRecord('sys_user_group');
groups.addQuery('u_restricted', '=', 'true');
groups.addQuery('active', '=', 'true');
groups.query();
//query groups to return if the ticket is restricted
while(groups.next()) {
assignment.push(groups.getValue('name'));
gs.log("DP: RefQual: " + assignment);
return assignment;
Incident Management
10-31-2019 10:09 AM
Hi Chad,
update code as below; you need to have the return statement after the while loop ends
also in reference qualifier script update this; you need to let the query know which column the script include function is returning so accordingly it will filter the records
var assignment=[];
groups.query();
return 'nameIN' + assignment;
10-31-2019 10:25 AM
This got it! My mistake was not having the return after the while loop and as you said must let the query know which column I'm filtering so I was missing the 'nameIN' portion. Thank you all for your help!
10-31-2019 09:53 AM
Hello Chad,
This thread will help you to solve your issue:
Please mark as Correct Answer and Helpful, if applicable.
Thanks!
Abhishek Gardade
Hexaware Technologies
10-31-2019 10:06 AM
Check out this code:
var gp = '';
var assignment=[];
gs.log("restricted: "+restricted);
groups.addQuery('u_restricted', true);
groups.addQuery('active', true);
groups.query();
gp += (',' + grp.group);
gs.log("DP: RefQual: " + gp);
return 'sys_idIN' + gp;
10-31-2019 10:39 AM
Just realized now I need to figure out in the if restricted = false segment how to make it not return groups that have been disabled. 🙂 wasn't thinking about that.
