Alert for confirmation after clicking a button
Abhi369
I have a button called "Cancel Request" on the top right corner of my form.
I want to create a alert/confirmation box with Yes and No button to prevent direct cancellation of the form.
I want a simple solution with a alert box only and not the UI Page solution. We already have a UI Action for this button but writing alert() or confirm() method of JavaScript is not working as that is Service side script.
Please help!
Thank you
Saurav11
Yes you can do it as below:-
function cancelIncidents() {
    var answer = confirm("Are you sure you want to cancel it?");
    if (answer == true) {
        gsftSubmit(null, g_form.getFormElement(), 'cancelincidents');
    return false;
For more information check the below post:-
https://www.servicenow.com/community/developer-forum/add-confirm-pop-up-message-in-ui-action/m-p/197...
Please mark my answer as correct based on Impact.
Hi Karan,
I cannot give you the exact code but it is similar to the below post's solution by Imran Ahmad. The only difference is that I have not checked the client checkbox and therefore I don't have that Onclick field to call the function.
Abhi369
Right, so you need to actually convert it to a client-side UI Action by checking the box, adding the function name in the Onclick field and the "gsftSubmit" will re-run the code in the UI Action, this time on the server.
ttttttttting
I have the same problem. Have you solved your problem
