Alternate solution for current.sys_id in Scheduled job run script
jobin1
The below code is working in BR but not in a scheduled job so what is the best way to replace gr.addQuery('sys_id', current.sys_id); in a scheduled job run script?
var gr = new GlideRecord('u_custom_integration');
 gr.addQuery('sys_id', current.sys_id);//not considering in scheduled job run script
 gr.setLimit(1);
 if (gr.next()) {
//tried gr.addQuery('sys_id', getUniqueValue()); but not working
@Ankur Bawiskar Any idea?
15 REPLIES 15
jobin1
gr.addQuery('sys_id', getUniqueValue());  //tried not working
Ankur Bawiskar
@jobin1
what's your business requirement?
you need to know which record should be queried with proper query conditions
the requirement is very difficult to explain actually  I just wanted to know how we can replace the gr.addQuery('sys_id', current.sys_id); in scheduled job run script as in br its works and gives the current record sys id
@jobin1
without knowing the requirement cannot help much
I have created an integration to crate Ritms through API and once the Ritm created through the BR I am sending back the ritm no and a few other details to u_custom_integration through the same BR.  for sending that I used the below query but its not working on the scheduled job, basically this scheduled job script  is similar to BR and its for triggering when the BR not run
 gr.setLimit(1);
 if (gr.next()) {
