09-03-2018 10:42 PM
Is there a way to always expand the order guide "options" on the service portal ?
aria-expanded="true" didn't seem to work.
Any help appreciated.
- 4,601 Views
09-10-2018 09:07 AM
I believe the logic is setup to always expand if the amount of "variables" is greater than 0, so always expanded if there's something there.
<div ng-if="data.variables.length > 0" ng-init="c.variable_toggle = true">
Are you saying you want it to always be expanded, even when empty? And to basically remove the toggle?
09-11-2018 05:38 PM
I want it to always expand if there is at least 1 item to show. Right now even if there is 1 item to show it doesnt expand.
